Setting up start time for charging
Prashney
Folks, every EV I have owned has an option to set up the time when the charging should start. This is particularly helpful at home when you plug in as you arrive, but charging starts at midnight when the rates are lowest. I couldn't find an option to do that in hummer. There is only a charge end time, which is not helpful. Any recommendations?
Start by setting your Home charging location in the charging app under the Gear icon in your car. Next, choose your Preferred charging time to align with peak and off-peak hours, and then create a schedule with your daily departure time. GM’s system is designed to finish charging as close as possible to your set departure time.
